526 replies to this topic
#501 toyo
  • PipPipPipPipPipPipPip
  • 45693 posts
Posted 31 January 2021 - 11:56
Ti serve abbastanza ferro da generare le correnti parassite q.b. per riscaldare quello che ti serve
Edited by toyo, 31 January 2021 - 11:56.
#502 faco
  • 12698 posts
Posted 31 January 2021 - 19:17
Sì ma si accendono solo se c'è abbastanza roba sopra ("abbastanza" dipende dal piano come dice sait)
Edited by faco, 31 January 2021 - 19:17.
#503 euthanasia
  • 48096 posts
Posted 31 January 2021 - 19:25
comunque mi rendo conto solo ora che in casa mia non potrebbe funzionare :asd:
ad esempio facciamo spesso le patate nel romertopf (che è di ceramica) e altri cibi cotti in contenitori "non tradizionali"
#504 toyo
  • 45693 posts
Posted 31 January 2021 - 20:22
sopra cosa scusa
#505 faco
  • 12698 posts
Posted 31 January 2021 - 21:36
sopra cosa scusa
Sul "fornello"
#506 toyo
  • 45693 posts
Posted 31 January 2021 - 22:13
eh quello intendo io - quanto ferro c'e' nella roba che ci mette sopra
#507 faco
  • 12698 posts
Posted 31 January 2021 - 22:14
#508 toyo
  • 45693 posts
Posted 31 January 2021 - 23:06
bene
#509 euthanasia
  • 48096 posts
Posted 31 January 2021 - 23:14
#510 faco
  • 12698 posts
Posted 01 February 2021 - 00:10
non ho capito se alla fine è carico
#511 balint
  • PipPipPipPipPipPipPipPip
  • 54837 posts
Posted 01 February 2021 - 09:15
Lo scopriremo dopo la pubblicità
#512 eglio
  • 41961 posts
Posted 01 February 2021 - 20:00
BA434230-FB77-4-A8-C-82-B7-6-C6-C100733-
“If you're wearing an unlocked crapple Watch and use Face ID as you normally would, the ‌iPhone‌ will unlock after a partial face scan. When the unlock happens, you'll feel a haptic buzz and will receive a notification on the crapple Watch informing you that the unlocking procedure was successful, similar to how it works when unlocking a Mac with an crapple Watch.”
#513 willy_revenge
  • 70597 posts
Posted 01 February 2021 - 23:45
Fap
#514 yorkeiser
  • 72467 posts
Posted 02 February 2021 - 02:21
Dio santo :pua:
#515 Berling
  • 66455 posts
Posted 02 February 2021 - 07:55
Fap
#516 willy_revenge
  • 70597 posts
Posted 02 February 2021 - 11:34
in b4 ora che esce è finito il coviddì
#517 mapomac
  • 36169 posts
Posted 02 February 2021 - 16:05
tutto molto indispensabile
#518 toyo
  • 45693 posts
Posted 02 February 2021 - 16:07
beh da quando c'e' il covid pagare con il ticchi-ticchi laterale dell'iphone e' diventato uno sbatti, ogni volta non mi riconosce con la mascherina e devo inserire il codice
as top unto appoggiavo la carta :vabe:
Edited by toyo, 02 February 2021 - 16:07.
#519 mapomac
  • 36169 posts
Posted 02 February 2021 - 16:09
usa un watch :vabe:
#520 toyo
  • 45693 posts
Posted 02 February 2021 - 16:10
eh guarda sei il primo a dirmelo :vabe:
non uso orologi accessori faggate
